1969 cadillac guidematic uestion
Started by 1969cadillac, January 02, 2012, 06:17:49 AM
1969cadillac
hello ! i have a 69 caddy deville that i have equipped with guidematic
i believe i have a problem with a defective eye - the unit worked a few times when i first installed it , but now does nothing!
the one i installed has 5958846 on the back of it and is a 4 wire one , wires :
green ( to driver control knob )
gray ( to foot switch )
light blue ( also to driver control )
yellow ( to power relay upper beam )
i have the opportunity to buy an NOS one that has the same number : 5958846 but only has 3 wires -  the wires are the same colors as above , but it doesnt have the yellow wire to the upper beam connection on the power relay !
my question is is this extra wire needed to make the unit work? or is another power relay needed / used - your thoughts please !
thankyou , Murray Mules
