check valve for 53 Cad
Started by jst, January 11, 2012, 04:05:44 PM
jst
Hi
I am starting to assemble my vacuum system (wipers, radio. washers). Should there be a check valve in the line coming from the fuel-vacuum pump ? My fuel pump has a vacuum pump on the bottom. Is there a check valve built into the fuel-vacuum pump ?   Thanks
Joe T
CLC #27640
USMC  63-68
1953 Cadillac series 62 COUPE
R Sotardi #11719
If you are using the original AC dual action pump there are check valves in both, the vacuum, as well as the fuel side. Ron
jst
CLC #27640
USMC  63-68
