trunk, is it Cadillac??
Started by Cooke, January 19, 2012, 07:33:10 PM
Cooke
I just picked up this trunk and as you can see it needs some work. I would like to recover it with the proper material, any ideas where I might get this?? Also it’s about 40inches wide 19 inches tall. It has cast aluminum black painted side or corner pieces and obviously the chrome latches. I still need to get it to a locksmith to open it. I will be using it as an accessory trunk on my '30 club sedan if it is at all correct. Any help on the material is appreciated, Martin.
Classic
Send a sample of the material or pictures to Bill Hirsch.  I'm sure he can suggest something.
Gene Menne
CLC #474
