1954 Series 62 horn
Started by Frank Palacio, January 25, 2012, 10:21:47 AM
Frank Palacio
Where are the fuses located on my 1954 Series 62 Sedan?  The horn is not working and I thought maybe it could be a fuse.  Also the right front running lamp and turn signal are not working.  Actually the parking lamps are working sporatically (sp?).  They will be on and then go off.  Any ideas?
Frank
Walter Youshock
There's no fuse for the horns.  They are "hot" at all times.
It could be your horn relay, bad ground, frozen or rusted horn diaphragms or even a problem in the steering column.
Remove the horns from the car and test them with a battery charger.  connect the ground to the horn bracket and touch the positive cable to the wire plug.
As for the lights: sounds like a ground issue there as well.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
Frank Palacio
