KNEE ACTION SHOCKS
Started by Chasmann, January 27, 2012, 07:21:57 PM
Chasmann
If one of the knee action shocks is leaking should I  have both redone. I'm asking because its 500 for both to be rebuilt and if its not necessary maybe I would only do one.Thanks Charlie M
1949 SERIES62 4DR SEDAN                                      1936 SERIES 60 4DR TOURING SEDAN
ccp49
I don't see a need to get both rebuilt unless there is some kind of mechanical problem you are experiencing.  Remember what the shock absorber does - it dampens the movement of the suspension; it does not control ride height.  So, if one is leaking and not opeating correctly, at worst I see the suspension characteristics differing between the sides.
Probably a good idea to eventually get to both, but maybe do one and then save some time and money for a bit before doing the other.
Dan Barbieri
Dan Barbieri
'49 Conv "in the works"
Cedar Rapids, Iowa
Jeff Maltby 4194
Seems high for rebuilding the fronts. Try Five Points Classic Auto Shock in s.calif.
Might also try refilling it motorcycle fork oil with seal swell.
Jeffo 49er chapter
CLC 1985
Honda Gold Wing GL1500
41caddy
YOU CAN TRY WWW.KANTER.COM THAY SELL REBUILT'S FOR ABOUT $200.00.THAY ALSO SELL DELCO SHOCK FLUID FOR $12.00 FOR 11 OZ. I USE JACK OIL MYSELF THAT WORKS FOR ME
Caddy Wizard
I would recommend Apply Hydraulics in NY.  They did shocks for one of my 49s in the past and did a fine job.  It should cost about $400.  Yes, you should do them both at once, in my opinion.
Art Gardner
1958 Eldo Seville (2/3 done)
Chasmann
Art. Once again thanks for responding.Apple is now getting 500.Everyone keeps saying how reputable they are.Its probably worth the little extra.I will do both as you suggested.Also thanks to everyone else who responded.Charlie M.        P.S. Art you never got back to me with the piece that goes under the headlight rim .My question is what  was the quality of the chrome?If in needs to be refinished I might as well keep the one I have.Please let me know.
