Series 50 sway bar bushings
Started by sly37, February 04, 2012, 02:49:50 PM
sly37
Looking for a modern part number for the front sway bar rubber bushings for my 37 series 50 coupe. Have the end links already. Any help would be great.
   D Schroeder
cadillacman
Dont know if it helps, i fitted Mercedes Sprinter van bushes, on my 49 Cadillac.
Chrome is my favorite color!
sly37
I have found some bushings that fit a 42 series 60 cad,  it doesnt specify the bar diameter though. would someone know the sway bar diameter of their series 60 cad?
                          D Schroeder
Jim Stamper
     Sly;
     I can't tell you about 1942 sizes but my 37-60 is 11/16". I locked the measuring tool on that and then tried it on my 39-50 (LaSalle) and it wouldn't go on the sway bar so the 39 it would appear is bigger than 37 so the 42 is likely bigger too.
        Jim Stamper CLC#13470
Fred Pennington 25635
Steele Rubber shows 37- 39 bushings  part # 70-0717-33
I could not find a set for my 40-50 series and used Steele 70-0627-33  I had to cut it down a little
If you go to Steele's website or their catalog you can see the dimensions
Good Luke
Fred P.
Fred Pennington, CLC 25635
1940, LaSalle 5019
1940 LaSalle 5019 parts car
1968 Ford Bronco
1973 Mustang Convertible
2012 Shelby GT500
sly37
Thanks so much checking it out directly
sly37
found and ordered the bushings through steele. thanks again, those are the last pieces I need for the entire front suspension/ steering rebuild.
