1963 transmission
Started by dadscad, February 15, 2012, 02:37:52 PM
dadscad
I want to replace the tail shaft housing bushings and seal in the transmission of my 63 CDV. One supplier has the gasket, seal and a bushing claimed to be about 3/4 of the length of the factory double bushings. Supplier indicates it should work just fine. I haven't had the opportunity to view the inside structure of the housing and I can not visualize the difference. I would like to have input from someone that has actually been there-done-that.
Would a bushing, 3/4 the length of the original double set, be sufficient support for the drive shaft yoke? I am chasing drive line vibration, the bushings are the only thing I have not replaced.
David
Enjoy The Ride,
David Thomas CLC #14765
1963 Coupe deVille
David, if the vibration is coming from the tail shaft bushings, I would buy two of them , do them shorter to have the same lenght as original.
dadscad
Thank you, Roger. Good idea. It is one of the, "Well DUH"! moments, why didn't I think of that??!  :o
I'm still looking, If I don't have success finding the 2 originals, this is what I'll do.
David
Enjoy The Ride,
1963 Coupe deVille
Did you ask Dave Edwards? Phone 781 449 2065 or his e-mail: autotran@autotran.us
