Flow pattern of the Transmission cooler lines for 1962
Started by CarlSpackler, February 20, 2012, 03:03:10 AM
CarlSpackler
Can anyone confirm the routing and flow pattern of the Transmission cooler lines for 1962 ?
The general shop manual (figure 6-1)  differs from a transmission service manual I have. Also, figure 6-27 in manual also appears to reverse the outlet and inlet at transmission creating further confusion. My engine is disassembled so I can not test flow at the ports.
From the shop manual figure 6-1:
Outflow lower transmission cooler port > In passenger side low radiator cooler > Out driver side low radiator cooler > Inlet at upper cooler port transmission
Anyone have a stock set up to compare?
Does it actually matter which side the cooler lines enter or leave the radiator?
60th Anniversary 1962 Eldorado Biarritz
Gunga Galunga
Gene Beaird
I'll preface this with saying I don't own an early-60's Cadillac, but have spent some time with mid-60's onward GMs.  I am pretty confident that the inlet and outlet on the radiator won't matter.  It's basically a flattened tube that runs through the bottom of the radiator.  There's no thermostat inside the radiator to open or close, like in some late-model oil coolers.
I'd think that if you were running solid steel line, it'd be pretty obvious which line goes where on the transmission, but again, I don't have one of those cars to look at.  If you're running transmission hose, I can see where the confusion would be.
Gene Beaird,
1968 Calais
1979 Seville
Pearland, Texas
CLC Member No. 29873
CarlSpackler
The reason I ask is because new reproduction  lines (Inline Tube) that are suppose to be as stock seem to best fit opposite to what my original lines were hooked up - though my originals were deformed and not the same as the new lines so I was not certain if they were correct or not, or if the new lines were shaped correctly. The new lines have complex bends so the positioning is not obvious but the best fit is opposite the manual.
Gunga Galunga
