32 LaSalle Carb kit
Started by mike12485, March 17, 2012, 08:13:52 PM
mike12485
Hello Everybody,
Looking for a rebuild kit for my 32 LaSalle carb, I think its a Johnson. Also looking for a fuel pump kit.
Best,
Mike Spera
CLC #26855
Mike Spera
Jim Stamper
     You want a kit from the guy who took over Charles Selleck's kit production after he died. I thought they were great. I don't recall the name right off but someone will.  The cork float is replaced by a brass one ans so on.
               Jim Stamper CLC#13470
Johan Boltendal #158
Pete Sanders is the gentleman that took over Selick's parts, Classic and exotic service sells the carb parts as well,
http://www.maritimedragracing.com/then_and_now_automotive.htm sells the pump repair kits .
I've used all three to my satisfaction. I personally do not see the need for a brass float, whenever I find them
in a Johnson carb, I take them out, I love the use of the old float hinge and fitting floats.
Johan
