Rubber Fuel Line? Where to find!!
Started by 58CAD, March 22, 2012, 09:11:40 AM
58CAD
I am looking to replace the rubber fuel line that goes from the main steel line to the fuel pump on a 1958 Cadillac. No parts supplier seems to carry any such thing. The closest line at NAPA is too long. This line is driving me crazy! Any help will be much appreciated! Thanks
Nick Radivan
J. Gomez
Quote from: 58CAD on March 22, 2012, 09:11:40 AM
I reply to a similar post on this subject;
The thread is;
http://www.cadillaclasalleclub.org/forum/index.php?topic=117889.msg196883#msg196883
The info is;
Bob,
From the AACA site, Donal_G posted the following;
CADILLAC
NAPA part # OEM part #
1941 - 48 WH 11076 1442527, 1451365
1949 - 58 WH 11093 145497
Hope this helps..!
Good luck..!
J. Gomez
CLC #23082
58CAD
Thanks J! I had checked with NAPA and the product came back as 18" and the original is around 12" - 13". Will the one from NAPA be too long, and get in the way of fan belts & fan?
Nick Radivan
Walter Youshock
I got them from NAPA and they are the correct length, Weatherhead lines.  I have the part # at home.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
58CAD
Walter can you check if the part number is:  WH 11093
That would be a great help to see if the same part that I had NAPA look up for me.  Thanks!
Nick Radivan
Walter Youshock
That number sounds very familiar but I can't attest to it right now.  I will say this much:  I found an NOS AC line at Carlisle years ago and installed it on my car.  In less than a week, the ethanol-laced "gas" started to deteriorate the rubber.  Since I installed the new Weatherhead, I've had no problems with today's fuel.
Do yourself a favor--order 2 so you have a spare.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
Jay Friedman
Some, not all, NAPA stores can make up a rubber line according to Weatherhead (WH) specifications if you give them the WH part number.
1949 Cadillac 6107 Club Coupe
Decatur, Georgia
CLC # 3210, since 1984
Glen
Glen Houlton CLC #727
CLCMRC benefactor #104
Walter Youshock
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
58CAD
Nick Radivan
