Founded 1958
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Forum Rules
Calendar
Login
Register
CLC Home
Forum Rules
General Discussion
(Moderators:
Lars Kneller 8246
quadfins
Barry M Wheeler #2189
Bill Hedge CLC 14424
Looking for a Magic Wand for use on annodized aluminum grills
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Looking for a Magic Wand for use on annodized aluminum grills (Read 1619 times)
Jeff Wilk
J. Wilk CLC # 25630
The Past + The Future = My Heaven on Earth
on:
April 07, 2012, 07:49:12 AM »
Short of finding a magic wand, is there some "quicker fix" to clean up the annodized aluminum grills on the late 50's Cadillacs? Mine is a 59 and I DO NOT want to attempt to disassemble the entire thing at this point.....that will be another project in a few years.....just looking to see if anyone has found some clever way to spray these down with something, scrub them up a bit with the assembly off the car, and then return assembly to car.
Buffing with a dremmel while on the car maybe??? With what?
Chrome cleaner and a toothbrush???
I've used chrome cleaner with a rag and that does a decent job but takes about 10 minutes per 2"square!!
I don't expect magic, just some way to give these some shot of newness, as they currently are looking sad.
Anybody try anything before that does a decent job?
Logged
Southern New Jersey
SOLD
1958 Cadillac Sixty-Special
1958 Cadillac Sedan
1958 Cadillac Coupe Deville
R Schroeder
Guest
Re: Looking for a Magic Wand for use on annodized aluminum grills
Reply #1 on:
April 07, 2012, 11:30:10 AM »
I did a Google search = How to clean anodized aluminum.
This was one thing I found.
http://www.secondchancegarage.com/public/665.cfm
Logged
curly
Reply #2 on:
April 07, 2012, 01:54:02 PM »
I have a 59 and I cleaned the grill (off the car, assembled) using a dremel and a soft, bullet shaped tip. I used regular automotive chrome polish on the tip and just took my time cleaning each square. It was a long time ago, I don't remember how much time it took, but the grill did look better, especially the side grills in front of the tire. They were almost black to start with.
I did burn out the dremel tool from over use. Not to worry, it belonged to my brother.
T Lewis
Logged
Ed
CLC Number: 23765
Reply #3 on:
April 07, 2012, 03:47:27 PM »
Try Autosol or Flintz, I have good results with these two products. In some area where you can use a large cotton ball, I would use it. Cotton balls cut, but don't scratch. Hope this helps. I use it on this car (see picture).
Ed Nieves
Logged
Ed Nieves
Member #23765
David Greenburg
CLC #3830
CLC Number: 3830
Name: David Greenburg
Reply #4 on:
April 07, 2012, 09:46:57 PM »
The most through polishing I've ever done on my '59 was with toothbrushes, lots of flannel cloths and Happich metal polish. It took my wife and I several hours with the grille off the car, but it looked real nice when it was done.
Logged
David Greenburg
'60 Eldorado Seville
'61 Fleetwood Sixty Special
okccadman
CLC Number: 5374
Reply #5 on:
April 07, 2012, 10:32:38 PM »
I used Barkeepers Friend and glass cleaner with a toothbrush on my 67. It is time consuming but I was very happy with the results.
Logged
Jim Jordan CLC# 5374
Oklahoma City, OK
55 Series 62 Sedan
56 Series 62 Coupe
56 Fleetwood 75 Derham Limo
59 Fleetwood Sixty Special
66 Fleetwood Brougham
66 Superior Hearse/Ambulance
67 Fleetwood Sixty Special
68 Fleetwood Eldorado
76 Coupe de Ville d'Elegance
90 Brougham
92 Fleetwood Coupe
93 Allante
94 Fleetwood Brougham
02 Eldorado Commemorative Edition
Jeff Wilk
J. Wilk CLC # 25630
Reply #6 on:
April 08, 2012, 09:59:05 PM »
WOW WOW and WOW......based on the below string of replies......AND THANK YOU.......we tried one small hidden section with some BRASSO and a tooth brush.......MAGIC WAND....well almost...
I am going to switch to AUTOSOL with a drill/dremmel type small buffing tip next and that should do amazing work......Just cant get into a full restoration of the grill at this point after winding up as shown below after simply starting to clean up the engine bay WHILE we simply replaced the brake master booster!!!!
Logged
Southern New Jersey
SOLD
1958 Cadillac Sedan
R Schroeder
Guest
Reply #7 on:
April 09, 2012, 08:52:53 AM »
You will probably find that the buffing wheels on a dremmel wont last long.
tooth brush will probably work the best.
Good luck, you have a lot of teeth to brush.........ha
Roy
Logged
eldo59
Mauro Bonfitto
Reply #8 on:
April 10, 2012, 03:43:32 AM »
You may as well pull the grill apart seing as you've taken the front clip off.
It's not hard to do trust me. Once it's all apart it's reall easy to clean with autosol.
I did my grill and side pieces in one weekend.
Logged
Mauro Bonfitto
Ed
CLC Number: 23765
Reply #9 on:
April 10, 2012, 06:51:04 PM »
Autosol does a good job and if you want to give it a nice final touch, hit it with Zomel.
Last Edit: April 10, 2012, 09:16:18 PM by Ed
Logged
Ed Nieves
Member #23765
Print
Pages: [
1
Go Up
« previous
next »
General Discussion
(Moderators:
Lars Kneller 8246
quadfins
Sitemap
1
2
3
4
5
6
7
8
9
10
11
12
13
