stuck valve
Started by mr41cadillac, April 25, 2012, 04:03:19 PM
mr41cadillac
41 cadilac 346 engine. i have the engine heads off but one of the valves wont open. how can i free it up ? thanks john
Classic
I assume you are rotating the engine crankshaft and watching the valves open and close.  If one valve doesn't move, something below the valve head is wrong (broken valve, broken lifter, wiped cam lobe, etc.).  Freeing the valve won't fix any of those.  Remove the intake and exhaust manifolds and valley covers to see what the problem is.
Gene Menne
CLC #474
mr41cadillac
i have the timing chain off all valves will open but one the crang will turn all cylinders thanks john
kkarrer
John,
    The first thing I'd do is to put a little Marvel Mystery Oil on it...on all of them actually and let it soak in a while.  Then, using your starter or a socket and ratchet on your crank, turn the engine over and see if it loosens up, but you'll want to take off the valley cover (below the intake manifold) and check your springs and stems.  There's most likely something amiss between the cam and the valve stem.  A spring might have broken or a stem might be bent.  Also look for any broken parts in that valley area once you have the covers off.  Hopefully your cam lobe is ok.
Ken Karrer 1941 6227D coupe
Martin Michaels
John , was the engine running and something happened or had the car been sitting along time and your just going thru it ? Marty M
Marty  CLC#26833
1947 6269  Cavern Green
1980 CDV D Elegance  White
mr41cadillac
my valve was stuck in the guide. we freed it up with a cold chisle by turning the head of the valve. now i need one intake valve and one guide. also is there a tool for removing the guide/? thanks for everyone input
