a/c directional vent repair?
Started by Hankk17, April 29, 2012, 09:10:00 PM
Hankk17
so everyone knows this problem.. your dash vents in your 70's caddie are flippy and hang however they want to hang.  To fix this issue I've seen people stuff matches in the side, folded paper, business cards, the insides of bic pens, paper clips, you name it but that all looks pretty junky if you ask me.
So I ask you, Cadillac club - what is the RIGHT way to fix it?  Does anyone know of aftermarket adhesive foam replacement pieces to stick on the sides of the vents so they'll stay where I want them?
-Hank
Wherever you go... There you are
R Schroeder
I used 1/2 inch wide foam, that was sticky on one side. Bought it at the hardware store on a roll.
Just cut off a small piece and stick it on. I did pop the vents out to fix them.
Roy
jagbuxx #12944
I used adhesive felt on the sides of the vents once they were removed.
Frank Burns #12944
61 Coupe Deville Bristol Blue
41 Series 61 Deluxe Coupe 6127D Black
08 STS 3.6 1SC  Thunder Gray
16 GTI Gray
03 T-Bird Black
19 Tiffin Phaeton 40AH
07 Corvette Blue
20 MB S450 White
"Whatever the occasion, there
is no better way to arrive than in a Cadillac.
Hankk17
Yeah I was thinking felt more than using foam again.  How does it hold up in the heat?
-Hank
