47 convertible window washer
Started by Paul Tesone, May 02, 2012, 07:03:33 PM
Paul Tesone
I apologize for the out of focus photos . I hope that in spite of the poor quality , someone can recognize the parts and help. Two screws - a smaller one fitting inside a larger one attach to each other and in turn then get screwed into the main body of the wiper assembly. The washer fluid flows thru these screws . The first photo shows the larger of the two screws in the wiper assembly . The other two photos show both screws separated from each other . Note that the shank (?) of the smaller screw is not rounded , but has two flat surfaces. It also has a small grouve which  apparently directs the washer fluid . I need one of these smaller screws . Can anyone point me in the right direction ? Thanks in advance for your help . ..Paul Tesone CLC #6876
