Battery charging
Started by larry pitts, May 05, 2012, 09:43:27 PM
larry pitts
I have a eight volt battery in my 1950 Cadillac which works fine. My question is if i need to charge it which do i charge it with? 6volt or 12 volt since no 8 volt on chargers? Thanks #16625
Classic
Battery Tender makes an 8 volt charger.  Available at Amazon.  $52.95.  http://www.amazon.com/Deltran-Corporation-021-0152-1-5a-Tendr/dp/B003D5I66E
Gene Menne
CLC #474
Doug Houston
First, get rid of that 8 volt battery, install a good group 2 size lead-acid battery, or a 6 volt optima.
Secondly, rewire, if necessary, the feed and ground straps from the battery to the starter, and have new bushings installed in the starter.
Third, get rid of that worthless 8 volt battery. The car was built to start with a 6 volt battery and charging system, and if the car's electrical system is in proper shape, it will start and run perfectly.
38-6019S
38-9039
39-9057B
41-6227D
41-6019SF
41-6229D
41-6267D
56-6267
70-DeV Conv
41-Chev 41-1167
41 Olds 41-3929
