Ty,
These look exactly like the trunk hinges on my '42 series 75. The look is right and the length and hole to hole dimensions you give are spot on. However, I can't validate the numbers you give as I can't find any numbers on mine. I have a set off the car I'm comparing them to that I believe to be original and I can't find any numbers on them at all. I can find "LH" and "RH" markings in the castings.
Let me give you the interchange info on these in case they turn out to be the same hinge:
Part numbers: 4089541 (right side) and 4089542 (left side)
1937: 5011, 5019, 6019
1938: 5011, 5019, 6019S, 6119, 6519, 6519F, 75 (except 7557, 7557B, 7567), 90 (except 9057, 9057B, 9067)
1939: 5011, 5011A, 5019, 5019A, 5029, 60S, 6119, 6119A, 6129,
75 (except 7557, 7557B, 67), 90 (except 9057, 9057B, 9067)
1940: 5011, 5011A, 5019, 5019A, 5029, 60S, 72,
1941: 60S, 75
1942 - 49: 75
HTH,
