spacer on 1941 60 special
Started by mr41cadillac, May 25, 2012, 10:25:42 AM
mr41cadillac
 where does the spacer go on cranshaft pully? is it between the two pulleys or behind both of them ? thanks john
I'm unfamiliar with what you describe John, none of my flathead engines have the pulleys separate or a separate spacer, its all one unit.
mr41cadillac
on the cranshaft you have 2 pullys one larger than the other with a large washer or spacer
harry s
On the crankshaft you should have the balancer, generator/water pump pulley and the fan pulley. The large bolt that goes into the crankshaft has a large flat washer and lock washer. There is a flange with six holes that goes between the pulley assembly and bolts that hold it on.
Harry
Harry Scott 4195
1941 6733
1948 6267X
2011 DTS Platinum
mr41cadillac
thanks harry so then the flange goes on the outside of the outer pully or betwwen the 2 pullys? thanks john
Thats where its confusing me John, I have never had to dismantle the balancer pulley assembly. Yours has obviously been taken to pieces for you to have the pulleys and spacers separate.
harry s
Right, the flange goes on the outside of the outside pulley.
Harry Scott 4195
1941 6733
1948 6267X
2011 DTS Platinum
mr41cadillac
harry thank s that where i will put it kohn
