Author Topic: 1930 Cadillac V16 Spark Plug Gap  (Read 910 times)
Offline asiahm
  • Name: A Ahmad
« on: June 28, 2012, 12:10:01 AM »
What is the recommended spark plug gap (for Champion D-16 plugs) for 1930 Cadillac V16?
A.Ahmad
« Last Edit: June 28, 2012, 01:59:57 AM by asiahm »
Offline Chris Cummings
Re: 1930 Cadillac V16 Spark Plug Gap
« Reply #1 on: June 28, 2012, 11:39:59 AM »
Hi,
You probably already know that the factory recommended .025-.028".   See owner's manual and preliminary service data brochure posted at:
http://www.gmheritagecenter.com/gm-heritage-archive/docs/Cadillac/1930_Cadillac_V16_VVI.pdf
I assume they were assuming use of the GM-issue AC spark plugs, and I am unaware of any different recommendation specifically with respect to Champion plugs.
Hope that helps.
Chris Cummings
CLC 20072
Offline asiahm
  • Name: A Ahmad
« Reply #2 on: June 28, 2012, 01:50:20 PM »
Thank you very much for the info/ link.  I've been trying to locate the scan of V16 manual but couldn't.  ;D
A.Ahmad
« Reply #3 on: June 29, 2012, 10:37:37 AM »
I don't think the Heritage Center has posted the 1930-31 shop manual, but there are reproductions frequently offered for sale online (as well as the occasional original).
I'm pretty sure that the shop manual calls for the same gap dimension.  But I'll check my copy tonight when I get home.
Chris Cummings
Offline asiahm
  • Name: A Ahmad
« Reply #4 on: June 30, 2012, 01:42:44 AM »
The Heritage Center has 1930 V16 Owner's Manual as well as a Service Manual.  The plug gap is 0.025"-0.028" as mentioned by you.
A.Ahmad
All Cads
