1951 Sedan fuel filler apron
Started by wrench, July 07, 2012, 12:41:23 AM
wrench
I have tried to source this piece but have not found it. It is a die cut fiberboard apron that goes around the fuel filler neck where it mounts at the left tail light. I can fix this one, but if it is available as a replacement, i would like to do that  (depending on price, of course)...any info is appreciated.
Jim
1951 Series 62 Sedan
1969 Eldorado
1958 Apache 3/4 ton 4x4
2005 F250
2014 FLHP
2014 SRX
P W Allen CLC# 20193
Jim,
I was in the same boat with my 53. I don't think you will find a new one, but they are easy to make. I got a sheet of masticated rubber from Steele Rubber and made my own using the old one as a templet. See description below.
https://secure.steelerubber.com/search_frameset.php
Masticated sheet. 3/32" thick rubber sheet containing random milled cotton cord reinforcement for front end splash aprons, etc. This product is 4 foot high, and will only be sold in 4 (four) foot multiples (4' x 1', 4' x 2', 4' x 3', etc...). Used on most models.
70-0645-45.....$ 7.30/sqf
Paul
53 Coupe
Twin Turbine
wrench
Quote from: P W Allen CLC# 20193 on July 07, 2012, 08:13:30 AM
Jim,
I was in the same boat with my 53. I don't think you will find a new one, but they are easy to make. I got a sheet of masticated rubber from Steele Rubber and made my own using the old one as a template.
Paul,
Thanks for confirming this. Fortunately, I really only need to repair the ring that goes around the filler as the rest is still in pretty good shape...I will just reinforce the ring with some sort of fuel resistant rubber sheet, it will atually e an improvement as it will be easier to install it around the filler pipe neck...
Jim
1969 Eldorado
2005 F250
2014 FLHP
2014 SRX
