Founded 1958
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Forum Rules
Calendar
Login
Register
CLC Home
Forum Rules
Technical / Authenticity
(Moderators:
Lars Kneller 8246
quadfins
Barry M Wheeler #2189
Bill Hedge CLC 14424
72 Eldorado Speakers
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: 72 Eldorado Speakers (Read 1053 times)
Ryon1000
on:
August 10, 2012, 07:45:44 PM »
Hello One & All, Have an AM/FM radio w/ 8 track. 3 of my 4 speakers are not working. 1 in the back is. Tried grounding the other speaker in the back w/ no luck. Any suggestions what avenues to pursue when I dive back in? Thanks, Les
Logged
Tom Magdaleno
CLC # 25142
1938 Cadillac V16
Re: 72 Eldorado Speakers
Reply #1 on:
August 12, 2012, 12:43:35 PM »
If they are original I would start with replacing them. Other than that I would think its pretty simple, you have a power wire and a ground wire. Check the ohm rating of the original speakers and match that. Take out the good speaker and attach it to the wires of the other speakers and see if it works. If the power from the stereo is coming out then they should work. If its like my '71 Riviera then it should have 6x9s in the back and 3" or 3.5" speakers in the front. I just unhooked the fronts because they are mounted in plastic which is weak and also it makes pulling of the dash cover more difficult.
Last Edit: August 12, 2012, 12:45:33 PM by Tom Magdaleno
Logged
Tom
'38 Cadillac V16
'71 Buick Riviera
'65 Chevy Truck
'56 Packard Super Clipper
waterzap
CLC Number: 26896
Name: Waldo Du Toit
Reply #2 on:
August 12, 2012, 10:00:51 PM »
The impedance (resistance) of the older speakers are different than newer speakers. You can use older speakers on a new or old radio, but you need high impedance speakers for an old radio. New speakers are low impedance. Your old radio needs the high impedance or it will get damaged.
I got a set from this guy.
http://www.turnswitch.com/speakers.htm
Call him up, he is very good.
Logged
Charlotte, NC
-1978 Eldorado Coupe
Print
Pages: [
1
Go Up
« previous
next »
(Moderators:
Lars Kneller 8246
quadfins
Sitemap
1
2
3
4
5
6
7
8
9
10
11
12
13
