Steering Column Removal 1940 60S
Started by pauldridge, August 22, 2012, 09:03:28 PM
pauldridge
Any advice on removing the steering column?  I will be repainting it and dash soon.. don't really want to chance getting paint on my $6,000 interior!
Phil - Austin
Phil Auldridge
Austin, TX
Terry Wenger
As I remember, the steering column must come out underneath the car. So the car must be elevated to do that. I don't think it can be removed thru the engine compartment with the engine in place.
My advice ... mask very well!
Terry Wenger
Terry Wenger CLC #1800
tewv16@sbcglobal.net
1932 355B TSD
1939 7557
1940 60S
1941 60S
1947 6267 Conv.
1949 6207X Coupe
1963 60S
pauldridge
Hmm
This may windup being a brush-on job!
Phil Auldridge
Austin, TX
Paul Phillips
Phil
The gearbox and steering column come out as a unit from the bottom.  This is possible with the engine in place, but involves also removing the steering wheel, shift quadrant & linkage, wiring, etc.  It is one of those times to compare degree of difficulty between the methods.  Given you need to do both interior and presumably the engine side as well, it may be the better call to pull it.  I can copy the manual section for this if you need it - let me know.  Good luck!
Paul
Paul Phillips CLC#27214
1941 60 Special (6019S)
1949 60 Special (6069X)
