1948 Convertible Top Operation
Started by jgf, August 29, 2012, 01:07:37 PM
jgf
I'm trying to find out if the rear window on a 1948 Series 62 Convertible needs to be lowered before attempting to lower the top.  Owner's manual along with shop manual makes no reference.   Does anyone know for sure what is correct?
Thank you
jgf
25348
49 Convertible
Having had show a quality 48 and now a 49 convertible , both with the glass rear window I can tell you I have never unzipped the part of the top holding the window.  I would suggert that you always remember to use a strap to hold the top frame rigid when the top is down,  The strap goes from the footman's loop on the rear of the seat back to the slot in the top frame just behind the top latch handle.  Fold you top and roll as suggested in the owner's manual
HD
Herman Desser
clc # 19416
jgf
Thank you for your response.  It sounds like what you have been doing works, however, are there written directions that tell you about the rear glass during the lowering of the top?
Frank
