Make sure you have engine vacuum at small port of transducer. If so, then make sure the vacuum line from the transducer to the power servo is not clogged or leaking. If that vacuum line is okay, unplug the black and white wire going to transducer. System should go to full heat. If not, check to see if there is at least 10 inches of vacuum at the power servo. If not, transducer is bad. If there is at least 10 inches of vacuum, power servo is leaking. Tim
