Flathead Cam Spacer
Started by Paul Phillips, October 11, 2012, 11:39:35 AM
Paul Phillips
I am reviewing the parts manual in preparation for engine assembly, I find the the previous mechanic had left out the camshaft spacer, item AC on the diagram, p/n 142 9090.
I am presuming this goes between the thrust plate/retainer and the sprocket, but would appreciate confirmation.
Would also appreciate dimensions on this to see if I can locally source an equivalent.  Conversely, if someone has an extra one they can drop in an envelope, I would be happy to provide a thank you payment.
Paul
Paul Phillips CLC#27214
1941 60 Special (6019S)
1949 60 Special (6069X)
