Carb rebuilder recommendations?
Started by Dan M, October 16, 2012, 10:13:55 PM
Dan M
Any one have Quadrajet rebuilding service experience?  Want to make a recommendation?
THX!
Dan
Andrew Armitage
Andrew Armitage
Plainfield, IL
1941 67 Series
1966 Fleetwood 75 Series
1985 Seville
1991 Eldorado
jst
Hi
I would highly recommend Val Hedworth from Macon, Missouri. I have a 53 Caddy 331 that for a while gave me nothing but idle and exceleration problems. After I found a junk Quadrajet with the right Cadillac number, I had Val work his magic on it. When I got it back it looked like new. I droped it back on the manifold and almost had to make no adjustments. Car runs perfect.   Joe T
CLC #27640
USMC  63-68
1953 Cadillac series 62 COUPE
Walter Youshock
I second Daytona Parts Co.  FLAWLESS work, quick turnaround, flow-tested and adjusted and cosmetically beautifully cleaned and restored.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
EAM 17806
DAN:  I suggest you get in touch with Hobb's Carburetor Shop in Pelham, NH, tel # 1-603-635-2415. They are one of the best you're going to get to repair or buy a rebuilt carb. I have used them and found them to be very fair and knowledgeable in their work.  EAM
Ev Marabian
1976 Cadillac Coupe DeVille, 1989 Chevrolet Caprice Classic, 1990 Pontiac Bonneville and 1996 Buick Skylark
D.Yaros
As has already been indicated, one cannot go wrong by using Daytona Parts Co.  I was pleased, albeit all I did was buy a rebuild kit, and did the work myself.
Dave Yaros
CLC #25195
55 Coupe de Ville
92 Allante
62 Olds
Gene Beaird
^^ What Dave said.  Depending on the year, they can be stupid-simple to work on (I may be kind of tainted, as I do have some experience with them).  If it's a mid-70's or earlier carburetor, and you don't need throttle-plate bushings installed (it's not a common thing, but some do need it), then get a kit and DIY.  There are a couple of plugs on the bottom of the center section that may need to be epoxied, but go slow and don't make a big mess with it, and you can fix it yourself.  The spots needing epoxy have been discussed in another post on this forum just a few months ago.
Gene Beaird,
1968 Calais
1979 Seville
Pearland, Texas
CLC Member No. 29873
D.Yaros
Here is a link to a write-up, with photos, of the rebuild I did on my Rochester 4-Jet -
http://GrayLady.WebNG.com/carbrebuild.htm
It will give you an idea of what all is involved in the process.
Dave Yaros
CLC #25195
55 Coupe de Ville
92 Allante
62 Olds
mgbeda
I had a good experience with the Barker Gang Garage:
http://quadrajetcarburetors.com/quadrajet-rebuilding-service.html
Only bug/feature is they're at high elevation, so when they tune them and test them it's in thin air, and it would need to be retuned for your elevation.  I live near Denver so I didn't have to do that.
-mB
-Mike Beda
CLC #24610
1976 Sedan DeVille (Bessie)
Dan M
Well, with Hobbs Carubretors only 11 miles away I took my carb there.  Next day it was done and back on the car.  Runs much better.
Put in new shft bushings, choke pull off, etc, etc, $125.
There arec $400 rebuilders out there with 6 months leadtaimes, and the Daytona Parts Co did say they would bush the base plate and return in 1 day with a rebuild kit, but when Hobbs quoted me, I just had to try him.
I had planned to do the rebuild, but with the bushings and kit added up this was something I had to try.
He is not a siphisticated shop- for example, Cliffs High Performance claims to fix 41 design flaws in the carb, but I also did n't want to wait 6 months. :)
So, happy for now.  Thanks for the different inputs.
R Schroeder
Dave , your links just take me to an ad for web sites.
I can get your Olds for a second or two. The rest just go to an ad.
Roy
D.Yaros
Roy, Yes, I would say there is a prob right now with the links.  Thanks for the heads up.  I have contacted the service provider.
Dave Yaros
CLC #25195
55 Coupe de Ville
92 Allante
62 Olds
R Schroeder
Yeah, I enjoy following your stories about your cars, and I got locked out.........................ha
Roy
Dan LeBlanc
I did not know about Hobbs in NH. I'm only 1/2 hour from Calais, ME in NB and I was going to send my Carter AFB to Calgary AB. Now I'll just take it to Maine and send it from there.
Dan LeBlanc
