remove drive shaft 1941 cad. 60 special
Started by mr41cadillac, October 23, 2012, 07:39:17 AM
mr41cadillac
im removing engine fron 41 60 special. ive been told to remove drive shaft from rear end. does anyone have any tips ? thanks john
LeRoy DeVol
To remove the drive shaft all you need to do is remove the 4 bolts that hold the universal joint to the pinion flange, & pull the shaft out of the transmission. Make sure you drain the fluid from the transmission first.
Lee DeVol
If your removing the gearbox as well its wise to remove the drive shaft to prevent it dropping, just undo the bolts on the rear axle and the shaft will pull out the transmission. Watch for loosing fluid from the box. If your leaving the transmission in then you can leave the drive shaft in also.
