1991 Cadillac Brougham Sunroof button stopped working
Started by AC48, November 01, 2012, 11:52:14 AM
AC48
Earlier yesterday I tried closing the sunroof on my 1991 Cadillac Brougham and the button didn't operate. The Open and Tilt buttons work but the Stop and ASC button stopped working.  Any ideas????
Thanks in advance!
Tim Pawl CLC#4383
Are you a smoker?        My sister had a 1988 with a similar problem, her husband was a smoker. Tar from cigarette smoke migrates up to that area.   Cleaned switch with Q-tip and some rubbing alcohol, worked fine.  Q-tip was dark orange, showed what smoking can do.  They immediately stopped smoking.       Tim Pawl CLC#4383
AC48
Wow!!!!! Yes I am.... I will try that out and I need to stop smoking as well.  Thanks Tim!
Guidematic
Add a bit of tension to the fingers in the switch while you're in there. They tend to loose tension and can render the switch inoperative.
1970 Fleetwood Brougham 68169
1985 Eldorado Coupe 6EL57
1988 Eldorado Biarritz 6EL57
1994 Fleetwood Brougham 6DW69
AC48
