Founded 1958
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Forum Rules
Calendar
Login
Register
CLC Home
Forum Rules
General Discussion
(Moderators:
Lars Kneller 8246
quadfins
Barry M Wheeler #2189
Bill Hedge CLC 14424
1960 Eldorado NO HEADLIGHTS
« previous
next »
Print
Pages: [
1
2
Go Down
Author
Topic: 1960 Eldorado NO HEADLIGHTS (Read 3864 times)
60eldo
EVERYDAY ABOVE GROUND IS A GOOD DAY
Name: Jon Kluczynski
on:
November 04, 2012, 05:26:57 PM »
I have no headlights in my car, I have rear lights but no headlights,,,,Could it be the dimmer switch?
Logged
Jon. Kluczynski
CLC Number: 22443
Re: 1960 Eldorado NO HEADLIGHTS
Reply #1 on:
November 04, 2012, 06:17:25 PM »
That's a good start. My lights on my 76 sometimes don't come on. When I switch from high to low a few times they come on.
Let us know.
Logged
CLC # 22443
I prefer email's not PM's rachlin@comcast.net
Reply #2 on:
November 04, 2012, 06:34:21 PM »
Get a test lite on the dimmer switch, look for current in and then out, basic diagnostics.
Logged
60eldo
Reply #3 on:
November 04, 2012, 06:52:38 PM »
Didnt even think of that,,,thanks,,I will test it now
Logged
Jon. Kluczynski
60eldo
Reply #4 on:
November 04, 2012, 07:07:17 PM »
OK I checked for power to dimmer switch,,,,Nothing,,I followed the wire from the dimer switch and it goes up into the left kick panel then I cant see where it goes,,,looks like it goes into the upper Left fender by the door
Logged
Jon. Kluczynski
62droptop
Guest
Reply #5 on:
November 04, 2012, 08:00:34 PM »
do you have the guideamatic auto dimmer also??
Logged
60eldo
Reply #6 on:
November 04, 2012, 08:08:45 PM »
Is that the autronic eye?
Logged
Jon. Kluczynski
60eldo
Reply #7 on:
November 04, 2012, 08:29:35 PM »
yes it has it,,,is that the box i see in the left kick panel?
Logged
Jon. Kluczynski
60eldo
Reply #8 on:
November 04, 2012, 08:33:56 PM »
heres the car,,,hope to drive it someday,,,,,,,,,,,
Last Edit: November 04, 2012, 08:37:21 PM by 60eldo
Logged
Jon. Kluczynski
R Schroeder
Guest
Reply #9 on:
November 05, 2012, 06:20:46 AM »
Wow, it looks like you have a few problems there.
Roy
Logged
62droptop
Guest
Reply #10 on:
November 06, 2012, 08:03:09 AM »
first thing to check is the switch
check to see if it is actually working by testing for power right out of the plug when in the headlight position
start at the source and work from there ,otherwise drive your self crazy
Logged
Guidematic
CLC# 19186
CLC Number: 19186
Reply #11 on:
November 06, 2012, 11:10:49 AM »
Oooo! Looks like there may be other ghosts lurking about in there. Do yourself a favour and get some good schematics. Proper diagnostics depends on the proper materials and know how.
Logged
1970 Fleetwood Brougham 68169
1985 Eldorado Coupe 6EL57
1988 Eldorado Biarritz 6EL57
1994 Fleetwood Brougham 6DW69
60eldo
Reply #12 on:
November 06, 2012, 11:17:55 AM »
I have the manual 1959 and 60 but its hard when everything is black and white,,I just bought wirring diagram in color, laminated, its great, but I think they still leave alot out. I think when Im done with this wirring project, I will be quaified to make my own diagram in color and maybe write a book,,,hahahaha
Logged
Jon. Kluczynski
linchero
Reply #13 on:
November 06, 2012, 11:50:54 AM »
same problem with my 60 seville. took out the dimmer and diconnected the high beam wire and done.
Last Edit: November 06, 2012, 04:18:25 PM by linchero
Logged
60eldo
Reply #14 on:
November 07, 2012, 04:09:36 PM »
No,,,I really need to get some headlights here,,Does anyone know where that wire goes from the dimmer switch to the left fender? Goes through the L kick panel then disappears
Logged
Jon. Kluczynski
60eldo
Reply #15 on:
November 08, 2012, 08:37:15 PM »
Ok WOW today I figured out and plugged in some more wires and I now have headlights,,,,,,,,,,,,,,,,,,,,BUT,,,,,,after about 10 seconds I hear a small CLICK near the fuse box and lights go out,,,,I wait about 30 seconds turn lights on again and they stay on for a few seconds and go out....WHY
Logged
Jon. Kluczynski
CLC Number: 22443
Reply #16 on:
November 08, 2012, 09:19:59 PM »
You have a short or very high resistance in the wiring and the circuit breaker is opening the circuit. DO NOT try to eliminate the breaker because your car will burn up.
Trace the wiring, start looking for broken insulation, any parts of the wire that may be touching metal or shorted together.
You may want to do a harness in the car if you have a lot of cut, spliced, or brittle wires. Patch jobs never work out well unless you can cut back to a solid section of wire, put in a section of the same gauge, and solder and shrinkwrap all connections. Butt connectors, electrical tape, it all turns to crap after a while.
brian
Logged
CLC # 22443
60eldo
Reply #17 on:
November 08, 2012, 10:18:08 PM »
Thanks Brian,,,this is a love hate relationship,,,I will figure out this mess
Logged
Jon. Kluczynski
60eldo
Reply #18 on:
November 08, 2012, 10:19:57 PM »
another pic
Logged
Jon. Kluczynski
Brian Daum
Reply #19 on:
November 10, 2012, 05:59:26 AM »
What kind of headlight bulbs do you have?
The headlight switch circuit breaker was designed for sealed beam. Sometimes when aftermarket halogen bulbs are installed they draw too much current, which causes the CB to engage.
Try switching back to sealed beams..
Logged
1956 Cadillac Fleetwood 60 Special
1959 Cadillac Coupe DeVille
1998 Cadillac DeVille d`Elegance
Print
Pages: [
1
2
Go Up
« previous
next »
General Discussion
(Moderators:
Lars Kneller 8246
quadfins
Sitemap
1
2
3
4
5
6
7
8
9
10
11
12
13
