glue for 1941 Cad rubber stone guard?
Started by wjhpc, November 17, 2012, 11:06:39 AM
wjhpc
My all rubber stone guards on my 1941 convertible coupe are pealing back. I would appreciate hearing the preferred glue to use. also are there any good tips on how to hold in place while the adhesive sets?
thanks,
Jim
Jim Harrison
LeRoy DeVol
Jim, The adhesive you should use is made by "3M" it is black and is designed for rubber seals etc. Install to the seal, let it set until partially dry, then press together. If you have excessive adhesive around the seal, use lacquer thinner for cleanup. When using thinner be quick so as not to damage paint. The "3M" product can be found at most auto parts stores in a tube for about $6.00. If the stone guard is not flexible it may be necessary to hold in place until the adhesive sets up. It only takes about 5 minutes for it to set.
Lee DeVol
wjhpc
thanks Lee. Heading to Ace now. Is paint thinner the right product to use to get rid of the older, crustey adhesive?
Jim
Jim Harrison
Bill Ingler #7799
Jim:   3M makes a product called General Purpose Adhesive Cleaner that I would use on old dried adhesive. Directions on can says allow the cleaner to soak into the old adhesive which if using lacquer thinner might damage the paint.     Bill
harry s
I used 3M double sided tape to attached the stone guards on my 67 series about 4 years ago and haven't had a problem. I put the tape around all of the outer edges and then across all of the inner area about 1/2" apart. The tape pretty much sets up on contact, but just to be sure I used small plastic clamps around the edges and masking tape where the clamps could not be attached.    Harry
Harry Scott 4195
1941 6733
1948 6267X
2011 DTS Platinum
Dan LeBlanc
I watched an episode of My Classic Car where a Steele Rubber Representative showed a proper demonstration on how to use the 3M weatherstrip adhesive. The key is to apply a thin film to both pieces, allow to cure for 10-15 minutes and then apply another thin film. Then stick the parts together. It's surprising how quick and strong the bond is when you do it this way.
I tried it myself and they are correct.
Dan LeBlanc
wjhpc
Thanks to all for the input on adhesives. I will tackle this project tomorrow.
Best,
Jim
Jim Harrison
