Cleaning 2003 CTS Chrome Wheels
Started by Matt CLC#18621, November 18, 2012, 03:03:55 PM
Matt CLC#18621
Can I use a BrilloPad to clean 2003 CTS Chrome Wheels?
Matt
CLC# 18621
Chris Conklin
I wouldn't. What's on them that you feel you need to scrub them like that?
Chris Conklin
Matt CLC#18621
Thick brake dust, grease and white chalky substance.
Matt
CLC# 18621
I like Maguires all wheel cleaner and a brush.
They do make Brillo pads that are nylon, not steel wool and they won't scratch the chrome.
0000 steel wool won't scratch the chrome either and you can use it on a lot of other things.
Once you get it wet, throw it out. It will rust quickly. So will any shards you leave behind so make sure you rinse completely if you go that route.
A couple of doses of wheel cleaner and. Brush should do it though.
Gene Beaird
Are they really chrome?  'white chalky substance' hints at aluminum oxide, meaning they're polished aluminum.  If aluminum, they _should_ be clear coated.  I'd gently clean them like the others have mentioned above, and then evaluate if they are indeed chrome, or aluminum.  If aluminum, perhaps they need to be cleaned up and a fresh clearcoat sprayed on them.
Gene Beaird,
1968 Calais
1979 Seville
Pearland, Texas
CLC Member No. 29873
Matt CLC#18621
Quote from: Gene Beaird on November 19, 2012, 02:25:34 PM
Yes, I believe wheels are polished aluminum.
Matt CLC#18621
Chris Conklin
Chris Conklin
