Founded 1958
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Forum Rules
Calendar
Login
Register
CLC Home
Forum Rules
Technical / Authenticity
(Moderators:
Lars Kneller 8246
quadfins
Barry M Wheeler #2189
Bill Hedge CLC 14424
1990 Fleetwood - Rough Idle
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: 1990 Fleetwood - Rough Idle (Read 2772 times)
gofast123
on:
November 20, 2012, 03:48:21 PM »
Thinking about buying a '90 with 53,000 miles on it. I'll see it in person on Thanksgiving morning but the seller already told me that it's idling rough. Other than that, the seller says it's an extremely clean car.
Just looking for some "best case / worse case" scenario possibilities from the forum.
Anything I should look out for in particular?
Thanks in advance... Gary Hodges
Logged
waterzap
CLC Number: 26896
Name: Waldo Du Toit
Re: 1990 Fleetwood - Rough Idle
Reply #1 on:
November 20, 2012, 03:55:39 PM »
Best case. Vacuum leak or something simple like a bad fuel injector, bad plug, wire, ignition coil. Timing could be off.
If it only idles rough, but runs fine, I would tend to think its a "simple and small" problem rather than the "big and expensive" one.
I think this is the 4.5 or 4.9 engine?
Check the oil. Should look like oil and not milkshake.
Coolant, check the transmission fluid. Tell the guy to leave the car and not start it before you get there. See if it starts easily.
Look at where the car is standing. Puddles of oil, or little drips?
That’s about all I can think of. The 4.5 and 4.9 were good engines, but you can still have coolant leaking into the oil, which is something you want to look out for.
Last Edit: November 20, 2012, 04:04:02 PM by waterzap
Logged
Charlotte, NC
-1978 Eldorado Coupe
936CD69
CLC Number: 26217
Reply #2 on:
November 20, 2012, 04:02:46 PM »
Assuming you are talking about a FWD with a 4.5, they are known to drop injectors. If the injector resistance goes way out of range the PCM may also need replaced. Not a huge deal if the car is nice otherwise, but figure $3-500. If one injector is bad, replace them all at once
Logged
Craig Brillhart CLC# 26217
CLCMRC Benefactor #302
gofast123
Reply #3 on:
November 20, 2012, 04:21:31 PM »
It is the 4.5... do all the 4.5 and 4.9 have the coolant leaking into the oil issue? is it inevitable in all of them?
why does this happen and can it be prevented?
I ask partly because I just bought a '93 DeVille with the 4.9 with 40,000 miles on it...
Logged
waterzap
CLC Number: 26896
Name: Waldo Du Toit
Reply #4 on:
November 20, 2012, 04:52:10 PM »
I have a 87 4.1 which is still running fine. Don't think the 4.5 had as many problems with the coolant leaks, but I guess it is still possible. Use the GM tabs, change the coolant and oil regularly, and you should be fine.
We are after all only talking about an intake manifold gasket that goes bad. If the manifold gasket starts leaking, look for the symptoms, and just have it replaced. Not the worst thing in the world.
Also check the oil often, glance at the water pump now and again to look for weeping.
I do think the water pump is not a great design. Being long and shallow, but I guess that's all they could fit.
Last Edit: November 20, 2012, 04:58:22 PM by waterzap
Logged
Charlotte, NC
Reply #5 on:
November 20, 2012, 07:23:32 PM »
All good advice, but from a diagnostic standpoint he really has no idea what the roughness is, as mentioned could be an injector, or wire, or plug if it is a misfire, or again. as mentioned a vacuum leak, Some checking is called for here to try and pinpoint the misfire cylinder, if in fact that is the issue.
Logged
Guidematic
CLC# 19186
CLC Number: 19186
Reply #6 on:
November 22, 2012, 12:27:47 AM »
The 4.5 was a great engine, especially by 1990. that was the first year for PFI on these engines and they were good for 190 HP.
Yes, injectors were a common culprit, but I would have a look see at the car first and come to your own conclusions.
FWIW, I have heard the injectors from a Chevrolet TPI engine work very well in these engines, and are considerably cheaper. It must be noted that Bosch manufactures the vast majority of these injectors and there is a great deal of interchangibility. However you need to look at the resisitance and the flow rate of the injectoras to make your choice.
Logged
1970 Fleetwood Brougham 68169
1985 Eldorado Coupe 6EL57
1988 Eldorado Biarritz 6EL57
1994 Fleetwood Brougham 6DW69
CLC Number: 22443
Reply #7 on:
November 22, 2012, 12:03:22 PM »
The 4.5 and 4.9 engines were not know to have the same issues as the early 4100.
Coolant changes and adding the GM or Barr's leak pellets is recommended.
Logged
CLC # 22443
I prefer email's not PM's rachlin@comcast.net
Print
Pages: [
1
Go Up
« previous
next »
(Moderators:
Lars Kneller 8246
quadfins
Sitemap
1
2
3
4
5
6
7
8
9
10
11
12
13
