need correct paint on 41 60 special fleetwood engine
Started by mr41cadillac, December 06, 2012, 10:16:00 AM
mr41cadillac
as part on engine rebuilt i need to know the parts of the engine and compartment that are green and parts that are black . i am using the bill hirsch paint. is water pump housing black are metal vac. lines black etcetc thanks all john
A. Amman #15293
John, your engine block, intake manifold, oil pan, water pump, fan pulley should all be Cadillac green.  The vacuum lines should be plated in zinc or cadmium and appear metallic.  The fan, spark plug wire towers are eggshell black, exhaust manifold is porcelainized and black.  Breather on dipstick I have seen either green or black, starter and generator are black as is the air cleaner.  Inner fenders and firewall are generally body color.
A. Amman #15293
