1997 Northstar
Started by Matt 12861, December 11, 2012, 11:19:43 AM
Matt 12861
My daily driver '97 De ville has 137000 miles on it.  About two years ago I had the head gaskets replaced and new longer studs put in.  The oil light just started flashing intermittently a couple months ago, so fast you might not catch it.  It only happens when the engine warms up and is idling.  It never stays on for more than a second.  I finally put in some STP and it quit flashing for about a week and started again.  I made the investment on the new head bolts hoping I could get five more years out of it.  Does it sound like an expensive fix?  Bad bearings?  I didn't look for any recent posts about oil additives for newer cars, but I noticed there are a lot more to choose from than STP, some are kind of expensive.  Any suggestions to keep it on the road at least one more winter?
Thanks, Matt
12861
Matt Givler #12861
Only real way to tell what is happening here is to pull the oil pressure sensor and attach a mechanical gage and get a direct oil pressure reading, then post back for more advice.
