I'm stumped--what's this?
Started by Brorag, December 20, 2012, 10:55:04 PM
Brorag
(attached) appears to be old fashioned ceramic 20 amp 220 volt receptacle--what's its purpose?
J Dellinger
Definitely aftermarket, well, actually, ex housing.
I am thinking that someone wanted to install a trouble light, and only had household fittings to work with.
Check to see what voltage is at the terminals with a multimeter.   Test on the high scale first, so you don't blow the meter up.
Classic
Maybe it's an easier way to connect a battery charger, as batteries from that vintage car were not always the easiest to get to.  On my '37 Cadillac (battery under drivers seat), I have the ring terminal cables that came with my Battery Tender connected to my battery terminals so all I have to do is plug in the cable from the Battery Tender.  It makes it easy to connect my Battery Tender.
Gene Menne
CLC #474
That is sort of what I was thinking that it likely was a power connection that a previous owner put on.  They just used connectors that were easy to source at the time.   It may have been for something like a charger or perhaps some sort of accessory that maybe the owner moved between cars?
buicksplus
Hey, your car's a hybrid and that's a plug for the electric motor that's hidden inside!
How about that odd light next to it?  Looks like a trouble light on a retractable cord like Pontiacs had in their engine comparments for years.
Bill Sullivan CLC# 12700
Guidematic
Follow that wire and see where it goes to.
1970 Fleetwood Brougham 68169
1985 Eldorado Coupe 6EL57
1988 Eldorado Biarritz 6EL57
1994 Fleetwood Brougham 6DW69
Martin Michaels
I'll take a W.A.G. at it. Previous owner lived in the mountains, It's a plug in  block heater.
Marty
Marty  CLC#26833
1947 6269  Cavern Green
1980 CDV D Elegance  White
I doubt if it was for plugging the mains power into as there would ve a safety issue with a live plug on the end of an extension cord.
Brorag
#8
the other ends of the plug go ground and the starter. Since the starter is connected directly to the battery, it could be used as:
--charging point for battery
--extra juice for cold starts
jepstr67
OBD2 port?  ;D  (Sorry, couldn't resist.)
It looks like a 220v AC plug, but like the rest of you assume, I'd say a booster battery contact point.
Todd
1970 DeVille rag top.
