sabre wheel restoration
Started by Scott Robinson, December 25, 2012, 09:53:29 PM
Scott Robinson
Hi,I have a set of gold sabres I need to restore and wonderd if there is a "kit" for replacing the rivets(I am guessing I need to dismantle them)
A wheel guy over here said he could drill and Tap them then fit high tensile studs instead of rivets,does anyone know if this is the only option
thanks Scott
1956 biarritz
1957 coupe deville
CLC member south Australia
Mike Josephic CLC #3877
That's a job best left to a professional.  The wheel must be taken apart to replate it.
However, upon reassembly it has to be "trued" and rebalanced to insure safety.  Only
a specialized shop would have that equipment.  Also, I would not substitute just any
type of rivet or fastnener for this job.
The best in the country is Valley Wire Wheel in CA.  Call and ask for Mike.
Valley Wire Wheel Service
14731 Lull St
Van Nuys, CA 91405
(818) 785-7237
1955 Cadillac Eldorado
1973 Cadillac Eldorado
1995 Cadillac Seville
2004 Escalade
2011 Buick Lucerne CX
CLCMRC Museum Benefactor #38
57CaddyBiarritz
Scott,
I'd agree with Mike that this is best left to a professional.  I just had the set on my 57 Biarritz done by King of Trim in California.  Very happy with the results.
John
Bill Podany #19567
Scott,
Follow Mike Josephic's advise on Valley Wire Wheel Service; they are the best in the country for Cadillac Sabre Wheels.  They restored the wheels on my 55 Eldorado back in 2007 when my car was restored completely after an engine fire.  It is time consuming, and costly, but those wheels are like jewels today.
Bill Podany
Knoxville, TN
1941 60 Special Fleetwood
1955 Eldorado
Scott Robinson
thanks Guys,
the place I took them to is a professional wheel and rim shop and they said the studs they would use would be the same as they use on drag cars
as I am in Australia no one really does them here and I would like to have them 100% original I thought there must be someone who sells the rivets and I could supply them to the shop
I will contact valley wire wheels and see what they say
cheers from Aus,Scott
1956 biarritz
1957 coupe deville
