99 Northstar - Power Steering
Started by Series75, January 08, 2013, 08:15:19 PM
Series75
OK, I am replacing the P/S pump and want to first flush the old fluid out and replace with new,  any guidance on which hose to remove to route to a catch canister?  Is it at the pump, or at the rack?  If at the pump is it the line bolted into the pump or the one with the hose clamp?  In other words - Which one is the return line?   Thanks Tom CLC#6866
936CD69
The clamped one.... pressure side is much higher hence the flared fitting.
Craig Brillhart CLC# 26217
CLCMRC Benefactor #302
Series75
Thank you much Craig.  Tom CLC#6866
