The oil leak issues from between the upper and lower crank case was largely resolved. The engines built in 1993-1994 were the most susceptible. However high oil consumption is an issue that plagued them all, right from the get go. But GM never recognised it as a problem, they just changed their oil consumption guidelines. However, incorrectly checking the oil level can lead to higher consumption as well. The engine must have been shut off for 20 minutes so that the oil in the upper engine can properly drain back to the pan. If this is not done, a false reading will result. Adding an extra quart will result in excessive fogging in the crankcase, which is then burned off either through the PCV system, or by excessive wetting of the cylinders. Once the engine finds the correct level, then it will stop. Mike
