Author Topic: '56 sdv  (Read 744 times)
Offline bluebelle
  • Name: rick bryce
'56 sdv
« on: January 27, 2013, 04:30:49 PM »
Hi, guys. I've got a bit of a thing.... I am trying to take the trim off my back window so I can take my window out. I can't figure out how to get the trim off.  have various trim tools, but none seem to work. Does anyone out there have a tip for me?
Thanks tons
Rick
1956 Cadillac sedan deville
1954 Pontiac chieftain
1978 Chrysler new yorker brougham
Offline dplotkin
  • CLC# 26299
Re: '56 sdv
« Reply #1 on: January 27, 2013, 07:48:37 PM »
I believe those have studs with nuts, you will need to drop the headliner to access.
Dan
60 Buick Electra six window
60 Chrysler 300 F Coupe
62 Pontiac Bonneville Vista
63 Chevy Impala convertable
63 Ford Galaxie XL fastback
65 Corvette convertable 396
68 Chrysler New Yorker
Offline Roger Zimmermann
  • Switzerland
  • CLC Number: 21015
  • Name: Roger Zimmermann
Re: '56 sdv
« Reply #2 on: January 28, 2013, 02:37:45 AM »
The shop manual explains where the studs are. From memory, the side parts are attached with nuts and maybe the upper too. You have to look under the inside rubber lip. The lower one is attached to the body with clips. Anyway, the back seat is to be removed as well as the inside garnish mouldings.
