Rebuilding Alternator
Started by waterzap, February 07, 2013, 02:10:23 PM
waterzap
The alternator on my 97 is making a squeaking noise. Replaced belt, pulley, tensioner. They were also squeaking by the way. Now it’s the alternator.
I was thinking it would be great to have it rebuilt. Maybe with stronger bearings than the OEM ones. Is that possible?
Usually I just buy rebuilt alternators, but in this case the job to remove it is so tough, I don’t EVER want to do it again.
Leesburg, AL
waterzap
Where would I be able to do that? Any idea the cost?
Leesburg, AL
I'm not familiar with a 97.  But I replace my alt front bearing every 60,000 miles
(and inspect the brushes).  Not expensive, if the alt comes apart OK.  I expect to
replace the brushes every other time, and maybe the rear bearing.  Bruce Roe
Rockauto.com shows a new Delco  3351049  for under $140.00.
It's a bear to get to, did the one on my 99 Eldo.  Your car will not have oil cooler lines to deal with so it's a bit easier.  Got to get it on a lift or on jacks, remove right front wheel and inner shroud and go at it.  Not fun.
If you want the best replacement a Cadillac exchange unit from a dealer is your best bet.
waterzap
Quote from: 76eldo on February 07, 2013, 07:30:08 PM
Saw that. Not sure what the difference between the different Delco alternators are, if any.
Leesburg, AL
Rock auto has a new Delco unit for $140.00.
