Rims, tube or tubeless
Started by Caddy_56, March 10, 2013, 04:55:04 PM
Caddy_56
Hi,
I have read that around 1955 tires became tubeless.
How do I know if the rims on my '56 can be used with 'modern' tubeless tires.
Is it possible to know, without removing a tire?
Doug Houston
Sure, don't worry about it. They're OK to use. I used tubeless tires on the first '56 Cadillac I had, when it was my everyday driver. I have tubeless tires on all of my '41 Cadillacs and '41 Oldsmobile. I use tubed tires on the '38 Cadillacs, the '39 Cadillac, and the '41 Chvrolet.
I also have a '56 Cadillac now, and a '70 Cadillac. Both have tubeless tires, and no problems.
38-6019S
38-9039
39-9057B
41-6227D
41-6019SF
41-6229D
41-6267D
56-6267
70-DeV Conv
41-Chev 41-1167
41 Olds 41-3929
