Author Topic: 1962 Bendix or Delco-Moraine?  (Read 3837 times)
Offline Edward Kenny
« on: March 28, 2013, 07:48:13 PM »
My 1962 CDV does not have the original master cylinder/power brake booster unit. Is there a way I can find out what braking system my car was delivered with?
Thanks in advance for the due diligence.
Offline quadfins
  • Jim Eccleston
  • Administrator
  • CLC Number: 16079
Re: 1962 Bendix or Delco-Moraine?
« Reply #1 on: March 28, 2013, 08:40:14 PM »
None that I am aware of. They were installed interchangeably - whatever was within arms reach at the time, I guess. Like with the carburetors, with no special or specific fittings.
Jim
Jim Eccleston
1961 Coupe de Ville
BATILAC
Senior Crown
DeCou Driving Award x 4
  • Name: Eric DeVirgilis
« Reply #2 on: March 30, 2013, 12:53:18 PM »
IIRC- Bendix brake booster was painted black; the Delco unit was cadmium plated. Some aftermarket manufacturers may have followed the same color scheme.
« Last Edit: March 30, 2013, 01:48:18 PM by ericdev #8621 »
Offline quadfins
  • Jim Eccleston
  • Administrator
  • CLC Number: 16079
« Reply #3 on: March 30, 2013, 01:23:51 PM »
Eric - you are correct about the finish.
jim
Jim Eccleston
1961 Coupe de Ville
BATILAC
Senior Crown
Offline Dan LeBlanc
  • Name: Dan LeBlanc
« Reply #4 on: March 30, 2013, 06:56:48 PM »
Your build sheet wont indicate Delco or Bendix just as Carter and Rochester carbs wouldn't be either. If you plan on being judged, I would think that as long as you have a 1962 unit under there, you'll be fine for authenticity.
The other way to tell the difference between Bendix and Delco units is Bendix units had four bolts on the master cylinder where the Delco had two to hold it to the booster. I've seen way more Delco units on these cars then Bendix, so if you want to go with the odds, go for a Delco.
Dan LeBlanc
Offline Coupe Deville
  • Name: Gavin William Myers
« Reply #5 on: August 06, 2013, 08:19:10 PM »
What type of booster is this? It is on my 1959 Cadillac Series 62 Convertible. Delco or Bendix? Any help is appriciated. Thank you.
Offline quadfins
  • Jim Eccleston
  • Administrator
  • CLC Number: 16079
« Reply #6 on: August 06, 2013, 09:19:37 PM »
That looks like a 1962 Bendix.
The shop manual has good illustrations of each.
Jim
« Last Edit: August 08, 2013, 06:06:49 PM by quadfins »
Jim Eccleston
1961 Coupe de Ville
BATILAC
Senior Crown
« Reply #7 on: August 08, 2013, 02:47:21 PM »
[The other way to tell the difference between Bendix and Delco units is Bendix units had four bolts on the master cylinder where the Delco had two to hold it to the booster. I've seen way more Delco units on these cars then Bendix, so if you want to go with the odds, go for a Delco.]
This would make it 100% sure it was a Bendix correct? Thank you for the quick responses.
