fuel sending unit
Started by jeffz, April 20, 2013, 07:11:14 PM
jeffz
I have a 1959 Cadillac 4 door hearse.
Is the fuel sending unit a 2 line type?
Would I have to drop the tank to find out?
What is a reasonable price for a fuel sending unit?
Thanks for any assistance, Jeff Zumbrun
A/C cars had the two connector sender units.  If it was a factory a/c car it had both lines.  If a/c was added afterwards, this may not have been modified as well (but it should have been).  Check the Cadillac parts places for a sender.  My 1970 sender was like $80 from USA Parts.
curly
i agree w/Scott, A/C cars had the return line. You can look at the fuel pump and see if the return line is there. I bought my sender from USA parts and had to pull it back out to reset the float arm. The calbration was way off. Check yours before you install it.
T Lewis
