Is it true?
Started by Renato, April 24, 2013, 02:16:41 PM
Renato
I read somewhere the 50's Cadillac has airplane engine. It means the steel engine block, and parts the same quality as they used for airplanes. It it true?
R. Bognar
KD
My Auburn has a lycoming engine in it.
I also had a PA-14 (Piper 4 place ) Airplane that uses the lycoming engines
Ken D
CLC#26801
Ken Dennison
1935 Auburn S/C Cabroilet
1929 Ford Closed Cab Pick Up
1960 Austin Healey Sprite
Philippe M. Ruel
Cadillac automotive engines were cast iron until the Northstar in the 1990s. Most aircraft engine blocks are aluminum alloy. What you heard sounds like an urban legend.
Cadillac flathead automotive 346 ci engines - that is, up to 1948 - were used in light tanks during WWII with few modifications.
During the same period, Cadillac has produced mechanical parts for Allison V-12 engines, used on Lockheed P-38s or Curtiss P-40s aircrafts. But never manufactured aircraft engine blocks or complete engines.
1952 60 Special in France.
Renato
Thank you the correct answer.
R. Bognar
Louis Smith
I believe only Oldsmobile had aerodynamic engines with their rocket 88 and rocket 98 engines.
Eric DeVirgilis CLC# 8621
#5
Quote from: Philippe M. Ruel on April 24, 2013, 03:24:49 PM
Just a clarification: Cadillac engines were cast iron until the HT 4100 in 1982 volume models.
The Cadillac cast iron 368 remained in production until the 1984 model year in the Limousine & Commercial Chassis models only. The Limousine had the 368  V-8-6-4 DFI; the 368 4bbl version was used in Commercial Chassis.
wrench
They did use 2 Buick 425 'Wildcat' engines to start the SR-71...
1951 Series 62 Sedan
1969 Eldorado
1958 Apache 3/4 ton 4x4
2005 F250
2014 FLHP
2014 SRX
cadillacmike68
And Packard built the Rolls Royce Merlin under license for the P-51 C & D models. That engine kicked the sh!t out of the Allison engines (used in the original P-51 B models) every which way.
"Cadillac" Mike
Walter Youshock
I do seem to recall Cadillac touting their engine machining tolerances were of "aircraft quality".  Can't recall if it was in an ad or some other promotional piece.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
Quote from: Walter Youshock on April 25, 2013, 09:09:02 AM
That was mentioned in Pride in the Possession.
RyanBurman
I always thought that the Cadillac tank engines were neat due to the exhaust coming out on top of the head instead of the bottom. Saw one in a hot rod and it looked pretty cool with the really swoopy headers the guy built.
Walter Youshock
Yep--"Pride in the Possession"  where "only the (industrial) diamond dresses the wheel" to machine "precision Cadillac engine parts".
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
Louis Smith
Quote from: Walter Youshock on April 26, 2013, 09:32:10 AM
Ah, so this is what "Pride in the Possession"  means!
https://www.youtube.com/watch?v=EnV-9527s4g
