1972 Eldorado ext. moulding clips
Started by abriddell, April 28, 2013, 02:56:26 AM
abriddell
I'm looking for moulding clips for the lower door trim and rocker panel trim for my 72 Eldo. convert.
Does anyone have any suggestions for sources?
Andrew Briddell
1972 Eldorado Convertible
jagbuxx #12944
Go to restorationspecialties.com they will have 95% of what you will need.
They supplied me with most everything for my '76 and '61
Definitely will have the lower rocker and door trim.
The one that you will have to improvise for is the clips for the small upper rocker molding on the front fender. It screwed in from the back if I recall and was a P.I.A to remove on mine due to access. I think they fitted the molding on the fender before the fender went on the car. In the original parts books they list a service replacement clip for that peice which of course is no longer available.
They did not have that one.
Frank Burns #12944
61 Coupe Deville Bristol Blue
41 Series 61 Deluxe Coupe 6127D Black
08 STS 3.6 1SC  Thunder Gray
16 GTI Gray
03 T-Bird Black
19 Tiffin Phaeton 40AH
07 Corvette Blue
20 MB S450 White
"Whatever the occasion, there
is no better way to arrive than in a Cadillac.
