Tigthening torques, 47 intake manifold/exhaust manifold bolts to cylinder heads
Started by FinCad, May 15, 2013, 02:49:56 PM
FinCad
Hi
I am lacking the repair manual for my 47 convertible.
What are the correct tigthening values from intake to cylinder heads + from exhaust manifold to cylinder heads ?
Thanks in Advance
Sami
Cadillac Eldorado Convertible 1955
Cadillac Eldorado Seville 1957
Cadillac Series 62 "flat top" 1959
Cadillac Eldorado 1967
harry s
Sami, The torque for those bolts including the crossover should be between 25 & 30 ft#. Be sure and start in the center and work your way back and forth to the outside. I think it is a good idea to start at 20#s and go in 5# increments and then go back and check them all. It is also a good idea to re-torque after running the engine up to tempurture the first time along with the head bolts.  Good Luck,    Harry
Harry Scott 4195
1941 6733
1948 6267X
2011 DTS Platinum
FinCad
