I have four wires to contend with. I've the ign wire to coil pos, thru ballast resistor. A neg ground inside distributor. Those two I know are correct. But, does the condenser wire go to back of points on nut, and from there a wire to the neg on coil?
I'm putting in points to double check my pertronix ignition. I'm pretty sure something's amiss there.
Thanks, Mike
