So you are looking at the heat-related vacuum switch that is in the block that operates the vacuum advance to the distributor when the coolant water is hot enough to open the internal port?
In this case, I cannot assist you, as I always convert any engine with this feature to full Manifold Vacuum to the Distributor for improved driveability.
The Workshop Manual should show it under Emission Controls System, and there should be a 12 Volt Speed Control Switch Vacuum Line to the centre port.
The port closest to the Block is the Manifold Vacuum port to the carby, the next is the Speed Control, and the outer one, to the Distributor.
This way, the Distributor can only receive Vacuum when the engine is warm enough, and the electrically operated Speed Control only supplies Ported Vacuum until that time.
Bruce.
