66 cadillac convert deville spring isolators
Started by ajordan, July 03, 2013, 03:35:26 PM
ajordan
Hello everyone,
I've had my 66 Cadillac convert for 12 years,  the squeaks and groans from the front springs are driving me crazy. Does anyone know where I can get upper and lower front sprint isolators that wont add an inch to the ride height? Most of the isolators I see have a half inch of rubber between the contol arms and spring raising the height 1 inch.  Thanks for the input Aaron.
John Bryan #21196
I bought some recently for a '67 from a online vendor called The Parts Bin, $14.13 each, Part #: M71BN110
Good luck.
John Bryan #21196
n2caddies
Not sure about the 66 but Steele makes a spring cushion that i have used on my 64 and 60 that isn't very thick that works well. I have sprayed silicone lubricant on all the new rubber joints to eleviate  the squeaking including the spring cushions. I have also seen fuel line split and wrapped around the first coil for the same purpose.
Randy
Randy George CLC# 26143
1959 Series 62 Convertible
1960 Series 62 Convertible
1964 Deville Convertible
2015 SRX
