leaky valve cover
Started by houstonlayne, July 06, 2013, 11:08:50 AM
houstonlayne
can a leaky valve cover gasket cause the car to run a little rough?
Houston Stafford
Allenton PA
1966 Cadillac sedan deVille
Houston,
With a PCV system any air introduced where it in not intended will upset the idle fuel/air mixture.
Some of the earlier valve covers just didn't keep the cork gaskets in place.  Might try some of that
blue gasket former instead of cork to stop the leaks.  Bruce Roe
houstonlayne
im going to replace the valve cover gaskets ..
RUBER or CORK ?
Houston Stafford
Allenton PA
I have never really seen a clear winner in the rubber vs cork debate.   I have had success and failures with both.  Big thing is making sure the cover is straight especially around the bolt holes.   I have heard that some light taps with a ball peen hammer with them upside down in the bolt areas helps spread the pressure further away from the bolt holes.  Gonna try that next time I have to deal with a leaker.
