Matt
My 78 has a flat terminal on the choke.
I'm sure if you go to NAPA they will have a connector that will work on your choke.
Sounds like someone changed the end on the wire to work on the previous carb.
I'll see if there is a part number for the choke, if my book shows it.
Roy
Ok the 79 carb has the following choke number , or part number. I don't think you will find it on the choke cover though.
C body , or coupe is 17062081
D,and Z body , or 4 door and Eldorado is 17061327
Again, take the cover to NAPA, and I'm sure they will have a connector for it.
No part number for the wire end in my book.
